93 Blazer
Old Apr 12, 2009 | 08:04 PM
ptg327's Avatar
ptg327 is an unknown quantity at this point
Question 93 Blazer
I'm looking at a 93 4.3 Vortec Blazer I want to buy but I have a problem. When you start it up it will run for about 10 seconds and then shut down. Also the fuel pressure is between 80 and 90. I think it might be a bad FPR or possibly a kink in a fuel line. What do you guys think before I buy it and I'm wrong.
Old Apr 13, 2009 | 08:02 PM
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
I'd first check for a kinked/blocked line first...
Old Apr 14, 2009 | 07:23 PM
80-90psi...? That is way high...
What does the fuel pressure do after you get the engine to run?
Old Apr 14, 2009 | 07:53 PM
GABlazer's Avatar
GABlazer is on a distinguished road
How well does it crank and how does it run for the ten seconds? If itll run that long should be getting fuel. In my experience with kinked lines they choke when u rev then die.
Old Apr 18, 2009 | 07:05 PM
ptg327's Avatar
I spoke with the guy this evening and he tells me that the fuel pressure is at 89 and that it stays at 89 after it dies out. He also says that when the key is turned it starts right up and runs fine for like 10 seconds. He seems to believe that it's an electrical problem and not a fuel problem. Also I'm told that it's getting no RPM when it run or when it dies. I'm not sure whats going on with this thing but all I know is that the thing is in graet shape with a panels and fenders replaced. If anybody can help out with this vague information let me know. Thanks
