| jarightnour |
Jan 19, 2011 01:49 PM |
93 full size blazer starting problems
well it starts up just fine when its cold but if i drive it for about ten minutes and turn it off it seems like i have to let something cool down before it starts back up.it wont even crank and the fuel pump dont kick on.the fuel pump fuse wire that connects to the firewall burned up so i replaced the section of burnt wire.the wires is a little more then warm when i touch it after i drove a little.anyone have this problem or suggestions before i start digging into the harness looking for an exposed wire?
