-   -   93 s10 wont start please help (https://blazerforum.com/forum/engine-transmission-35/93-s10-wont-start-please-help-84084/)
93 nightmare 01-25-2014 03:28 PM
Ok I have a 93 4.3 vortec that will not turn over... there is no fuel presser at the engine bleeder valve.. and the fuel pump does not make any noise anymore... so I checked the wire harness at the fuel pump and there is power when you turn the key... so I changed the relay just because dropping the tank isn't fun and nothing changed.. so I changed the fuelpump and still no change... so still I have no fuel presser what so ever and the new pump does not make any noise... NOTE.. the spiderinjectors are about a year old and fuel filter is 2 years old.. and the truck was running fine all day and an hour later went to go somewhere and now this... PLEASE HELP>>> thank you
abig84 01-26-2014 01:05 AM
make sure it has a ground too. some of the older vehicles had a ground wire that would run off the top of the tank and ground to the frame or body.
93 nightmare 01-26-2014 02:17 AM
yeah saw that when I removed the old fuel pump and just checked to make sure that I reattached it
