94 Jimmy won’t shift out of 1st..
The jimmy RUNS AND SHIFTS!! It fixed the problem. The guy that sold it to me must have replaced the vss buffer and forgot to hook it up correctly cuz when I found it I took out the two screws holding it to the ecm bracket and it fell out completely. No harnesses attached. I looked at it and it looked brand new. So I traced the harnesses for it. Plugged them in, reattached those screws to hold it in place and everything is working now.. Thank you all for the help. I really appreciate it
I also have a 94 Jimmy. Mine was sitting just below the heater core, probably would be the easiest to access from below the dash where the plastic sits but it sits just behind that glovebox. Is your Jimmy doing the same thing mine was? No shift? No speedometer or odometer.?
