94 no action when key nturned to start
:icon_bike: When the key is turned to start, there is no response. Battery fully charged, fuses check o.k.
check *S* terminal wire on stater and have someone check for 12 volts with the key turned to start, if yo uhave 12 volts (if not you have a open in the *S* wire and that needs to be repaired), try tapping the starter with a hammer(if this works you will need a new started due to bad brushes).
not alot to go off.
could be loose battery connection, no connection, starter burned up, ignition swich...etc. |
There is 12 volts to the starter but solenoid doesn't pull in (no click). I need schematic of starting circuit to find wiring info (neutral safety switch, etc).
thanks for suggestions/comments. |
There is 12V to what post on the starter solenoid?
There should be +12V constant to the large post that connects to the battery. When the key is turned to the 'START' position, there should be +12V on the small post of the solenoid that runs to the starting circuit. If there isn't, then you have a problem with something in the starting circuit. But please clarify where you are reading 12V... |
Seems like there should be more to that diagram...
what do you think is missing? thats the right diagram for a 94 blazer
i think like where each cycle of the key is broke down. i know alldata does that.
this just shows lock. |
Originally Posted by Ryanmatt135
(Post 301909)
| All times are GMT -5. The time now is 10:25 AM. |
