-   -   95 and 98 tranny (https://blazerforum.com/forum/engine-transmission-35/95-98-tranny-20256/)
waldon005 04-29-2008 12:07 AM
95 and 98 tranny
Does anyone know if a 4l60e out of a 98 blazer will work in a 95 blazer? Both four wheel drive four doors?
swartlkk 04-29-2008 06:14 AM
RE: 95 and 98 tranny
No. The '98 will have a 2 piece main case which is shorter in length (23.38" for the early 4L60E and 21.9" for the late 4L60E). Also, the bolt pattern for the transfer case (or tail housing if 2wd) changed between the early 4L60E (4 bolt (square) pattern) and the late 4L60E (6 bolt (hex) pattern).
blazin97 04-29-2008 01:19 PM
dang swartlkkyou amaze me atleast one a week with how informed you are about Blazers. I give you mad props.
waldon005 05-05-2008 03:28 AM
so there is no possible way that the tranny out of the 98 blazer will work in my 95 blazer?
swartlkk 05-05-2008 06:17 AM
Transfercase, front and rear driveshafts, and transmission and hope that everything works the same with the transfer case (I'm betting not). It isn't a simple plug-n-play...
Now, if there is a difference in the transfer case dimensions from mounting flange to both driveshaft mounts (tailshaft extension in the rear and mounting flange in the front) that equals the difference in length between the two transmissions, you would not need the driveshafts.
If the transfercases were to both be the 2 speed selectable (i.e. non-automatic), then you may be able to use your transfercase encoder motor, but I don't know that as fact. I don't have my references with me at work so I can't check the specific transfercase models used in these two years.
In the end, anything is possible, just depends on how much work you want to put into it. I would look for another single piece main case transmission from a 4wd...
waldon005 05-06-2008 03:52 AM
Well good news. I did have to use the spacer between the tranny and transfer from the 98 blazer other than that everything works perfectly!
swartlkk 05-06-2008 06:38 AM
So you used the spacer from the '98 to bolt up to your transfer case. Good deal! How did you cover up the front, lower portion of the bellhousing?
waldon005 05-07-2008 10:26 PM
i went back to the guy i got the tranny from and got the shield and put it on
