-   -   95 Blazer 4X4 Bumping all the time (https://blazerforum.com/forum/engine-transmission-35/95-blazer-4x4-bumping-all-time-92708/)
Joey Dodd 06-14-2016 08:12 PM
Ive had this Blazer for about 3 or 4 months. since ive had it i have consistently had a problem with it bumping. If i press the gas, after it kicks into first itll feel like its hitting small bumps. and it does it up until it hit 55-60 mph. If i lay on the gas in 1st or 2nd the bumps are extremely rapid, and if i let off the gas itll stop. i would love to have some help troubleshooting this.
Captain Hook 06-15-2016 01:46 PM
Sounds like either an engine misfire, or possibly a driveline problem, maybe a failing universal joint. Are there any trouble codes in memory, or is the check engine light on? Have you removed the drive shafts to check for worn/loose u joints?
