-   -   '95 Jimmy 4x4 Bad Acceleration (https://blazerforum.com/forum/engine-transmission-35/95-jimmy-4x4-bad-acceleration-94929/)
Tynan Tha Real Dill 07-11-2017 12:40 PM
Originally Posted by newguy (Post 678268)
scrolll down several sections and theres a pic of a fix you can do. They are called comression couplers/fittings
Ok I can't find that pic to fix the twisted fuel line. And on those loosen exhaust pics you seen, what are those parts called, how big are the bolts, and do they have gaskets?
newguy 07-11-2017 12:45 PM
sorry didnt add the link , they`re called flanges and I think thers gaskets. The auto parts store sohuld be able to help with and the bolt size heres the link https://blazerforum.com/forum/2nd-ge...-filter-91472/
Tynan Tha Real Dill 07-11-2017 05:26 PM
3 Attachment(s)
Ok I bought a straight pipe to temporarily replace the cat converter. The measuring tape pics are the measurements of the gap from the missing cat. The pipe I bought is 18" long and the holes are 2 1/2". The gap under my truck where the cat used to be is 14 1/2 and the pipe hole is 2 1/2. Is the pipe I bought too long? And should I have gotten a size smaller hole to slide it in easily? Also I bought bolt clamps to clamp it down.
newguy 07-11-2017 05:47 PM
cut the pipe with a hacksaw. you will need to buy adapters
to connnect them
Tynan Tha Real Dill 07-11-2017 05:50 PM
to connnect them
I need to cut the pipe? Is it too long? What about the holes is that enough to slide it in my exhaust pipes? And what adapters? The bolt down clamps won't work?
newguy 07-11-2017 05:55 PM
if the new pipe slides over the old you should be good. length and everything. if they are the exact same size you will need adapters
newguy 07-11-2017 06:01 PM
https://shop.advanceautoparts.com/p/...983%7CL3*15313
Tynan Tha Real Dill 07-12-2017 10:47 AM
What are the bolts to the flange that connect the exhaust pipe and exhaust manifold? Couldn't I just pull 6 good ones from a newer car or truck at a salvage yard?
newguy 07-12-2017 10:52 AM
I would get new ones from an auto parts store or hardware store
Tynan Tha Real Dill 07-12-2017 10:55 AM
Do they have to be those exact bolts with the springs or just a bolt and nut ?
