96 4.3 won't start
Old Apr 27, 2010 | 12:22 PM
klan52's Avatar
klan52 is on a distinguished road
Exclamation 96 4.3 won't start
ok, so I have a 96 4 door, 4 wheel drive, s-10 blazer with the 4.3 liter v6, with the 2nd gen spider injectors or cpfi, here's my issue:
.Engine turns over fine
.will fire off of fuel poured into throttle body, or starter fluid but shuts off right away
.fuel pump is good
.fuel filter is new
.fuel pressure is good
.pulled lines off top of injector and have good pressure there too
.no fuel mist or spray inside of throttle body
.starter relay good
.fuel pump relay good
.all fuses good
.crank sensor good
any suggestions? or should i just pull the entire intake and attempt to clean/replace the injectors? I'm pretty well stuck, can't think of what to try next short of pulling the intake and injection system off of another 4.3 and see if it will start
Old Apr 27, 2010 | 01:30 PM
rriddle3's Avatar
That doesn't really tell us too much. In the absence of the pressure numbers, have you read through this post?
96+ Fuel System Diagnosis
Old May 4, 2010 | 11:15 AM
klan52's Avatar
ok, got a chance to recheck fuel pressure today with two other gauges, apperently I had a bad gauge, only reads between 22-24psi, so I know my pump isn't putting out enough pressure, I have another pump and am going to swap it out to see if that would make any difference in my problem, anything else I should check while at this point?
Old May 4, 2010 | 12:09 PM
How did the pressure hold once the pump shutoff?
Old May 4, 2010 | 12:56 PM
klan52's Avatar
pressure stayed at 22-24 psi for about 10 min, then i released the gauge and removed it
andrewrj
May 6, 2012 07:28 PM
princered72
Sep 13, 2011 10:36 AM
Dark Rider
Aug 8, 2010 11:57 PM
1BSBAKER
Aug 11, 2009 10:54 AM
Irish10Hockey
Nov 13, 2008 02:48 PM
