-   -   96 4wd not fully disengaging? (https://blazerforum.com/forum/engine-transmission-35/96-4wd-not-fully-disengaging-32320/)
rraasch04 Jul 5, 2009 10:09 PM
Hi everyone,
Just bought a 96 blazer with 88K on in last weekend. Drove fine for about 1.5 hours on the way home then as I started to slow down it started whirring from the front passenger wheel area. As I came to a stop, at <5mph i could hear a ticking from the same area until I came to a complete stop. As I accelerated it did the same, out of curiousity I pushed the 4x4 button (oh yeah, since i didnt mention it has push button 4x4) it went completely away, pushed the 2hi button and it started up again. I pulled over and stopped. I continued to change it between 4hi and 2hi and could here from both sides something that souned like it was disengagin/engaging from the front end. After a few times of this I took off again and it went away. Today I had the same thing happen again, once again from the front passenger.
Any ideas? hub halfway locking in?
Thanks for any help.
swartlkk Jul 5, 2009 10:38 PM
Common problem. You either have a faulty vacuum switch on the transfer case, a partially sticking actuator cable (runs from the actuator under the battery to the front axle), or a problem inside the front differential. By far the most common is a faulty vacuum switch on the transfer case.
A quick search should come up with some good threads for your reading pleasure!
02BeachBlazer Jul 5, 2009 11:38 PM
either that or it might be your solonoid for your transfer case is goin out cause mine was out when i bought it it costed 345 at the dealer
rraasch04 Jul 6, 2009 09:42 AM
Thanks guys... that helped my searching alot didnt find much before... It does sound like the vaccum switch. I will have to give that a try.
