-   -   96 s10 4WD Trans bumping (https://blazerforum.com/forum/engine-transmission-35/96-s10-4wd-trans-bumping-17168/)
ArtTricks 02-11-2008 04:37 PM
Hello, i got a 1996 S-10 4WD Chevy Blazer, the transmission shifts real hard from 1st to 2nd...It does like if it would wait to long to shift then shift real hard...i changed trans oil but it havent help... any ideas? Thanks
ArtTricks 02-12-2008 09:10 PM
RE: 96 s10 4WD Trans bumping
And this is an automatic trans btw.
Hanr3 02-13-2008 09:43 PM
you got engine troubles?
If the tranny only acts up from 1st to 2nd it could be a sign of engine troubles. Or it could be a shift kit. Does it do it at all rpms, like under light peddle, moderate peddle, and heavy peddle, or when?
rriddle3 02-13-2008 09:51 PM
1-2 shift solenoid valve going bad maybe?
ArtTricks 02-17-2008 09:46 PM
thanks for your answer but the motor is crap...gotta change it
