96 Transmission issues
OK so I replaced the transmission in my 96 4 door blazer a week ago, everything works ok but Im having some issues that I can not pinpoint down, 1st is my gear shifter indicator does not work at all, every now and then I see the line in neutral if I wiggle the shifter around while in neutral. 2nd problem is my reverse lights arent working when in reverse, BUT if I shift to neutral and push up slightly on the stick they come on (still in neutral though) any thoughts, I've only ever worked on E4OD Ford transmissions and OLD Muncies before this truck so Im lost on it
Thanks in Advance
Thanks in Advance
behemoth
May 18, 2010 08:53 PM
chrisdavis23
Feb 27, 2010 09:23 AM
GloryImSaved
Jul 17, 2009 09:05 PM
sfesenko
Dec 12, 2008 10:03 AM
