I have a gas leak and am going to replace both the feed and return lines. Are these lines the same for both a 2 door and 4 door???? Thanks in advance
Dorman # 800-903 feed line some places say yes some say no???? All of the 800-905 return line say no???? Maybe a 5/16 patch is the way to go then?????? I see I should have put this in the General Help Tech |
800-903 is the pressure line, (3/8")
800-905 is the return line, (5/16") Both part numbers are for 2 door models only. |
I replaced my Master cylinder to rear caliper line (drivers side over frame rail) for $50.00 in parts with enough left over to do another ! A good source for tubing if you are doing it yourself is American Grease Stick Co. Poly-Armour® « Product Categories « AGS Company
Thank you sir!!!! Patch it is
.Put on Fuel injection rubber hose with double clamps on both ends Quick easy fix!!!
I'm glad too see you are roadworthy again ! Or off-roadworthy !
| All times are GMT -5. The time now is 08:28 AM. |
