97 blazer hesitates after traffic
97 blazer (260 thousand miles)hesitates after construction/traffic. When i try to get it go back to speed limit it hesitates will not go over 30/40 miles an hour. Have to pull it over turn it off and when I turn it back on starts right up and runs well. Took it to the garage after the first time it did it, mechanic said that he drove it cant get it to mess up.Has new spark plugs and coil wire. My 02 sensor my dad messed with so apparently that code will always show up as a problem. Sometimes i feel like i have to speed to keep it from feeling bogged down. HELP!
Funny you should mention this. After I lost the motor on my Bravada, I got involved with people who knew a thing or two about Blazers. Your scenario came up quite a bit in the discussions. According to what I've heard, it could be your 1-wire Knock Sensor either failing, or doing its job. :( on both counts.
Did you figured out the problem?
Originally Posted by Ricco
(Post 653134)
You just don't need your coolant topped off for no reason. Find the source of leak ASAP! It could be your lower intake manifold gasket, head gasket, etc.
Take a look at my photo album if want to see what happens when you don't figure out a coolant leak promptly. Wish you best of luck! |
| All times are GMT -5. The time now is 09:35 AM. |
