97 Blazer TDC Distributor Still installed
Hey everyone. Wife was driving down the highway when she ran out of gas. At the time we didnt know it and I had it towed to the house. I replaced the distributor rotor and cap. Engine is now showing codes for multiple misfires and runs very rough. Ive confirmed proper firing order. Ive been told the timing could be off and i need to find TDC on cylinder 1. I have not removed the distributor. Can i assume the rotor cap is pointing to cylinder 1? I can understand how to remove #1 sparkplug and rotate the engine by hand but how can I be sure rotorcap is pointing to cylinder 1? Ive heard mention of "bumping" the ignition to get the cap pointed to #1. I dont understand this concept. Any clarification would be greatly appreciated. Thanks!
Originally Posted by Dcodis
(Post 717753)
If you never removed the distributor, you shouldn't need to mess with it. My guess is that you crossed two of the wires. IIRC, two of the ones on the passenger side don't go in order (front to back), while the driver side ones all do.
*EDIT* Les types faster than I do. |
Originally Posted by Tom A
(Post 717758)
Wiring diagram used
https://cimg8.ibsrv.net/gimg/blazerf...834e17657e.jpg
I matched up numbers with eachother based off of this diagram. 1 to 1 so on and so forth. Do I have the wrong diagram? My distributor cap is marked this way as well. |
Originally Posted by LesMyer
(Post 717759)
Tom your efforts are appreciated. Typically we have the same answers!
(Post 717760)
This mean my problem lies elsewhere?
(Post 717762)
(Post 717763)
That's my guess. Do you have a fuel pressure gauge? I wonder if it's possible that the fuel pump was damaged by running dry.
If you can borrow one from your local parts store, it couldn't hurt to check. It's probably a long shot, though. I'm not sure what else to suggest.
| All times are GMT -5. The time now is 09:50 AM. |
