97 blazer tranny codes/shift problems
Old Apr 18, 2010 | 09:35 PM
gsquaredscrap's Avatar
gsquaredscrap is on a distinguished road
Default 97 blazer tranny codes/shift problems
i have a 97 blazer. Im getting these codes- p0740,p0753,p0758,p0785,p1860.
these are tranny shift solenoid codes and ive read other users that have had the same problems. how hard is it to change the solenoids? i also read that the ignition switch could be the culprit on a 97 and not the solenoids. as a blazer owner im noticing that they all seem to have the same basic issues i.e ( oil cooler lines, cooling, shift solenoids. ) i dont want to buy all the solenoids and put them in if its the ignition switch and i dont want to work on the switch if its the solenoids. anyone have any advice or some good general knowledge about this as to what i should do and what i should work on first.
Old Apr 19, 2010 | 06:12 AM
P0740 - Torque Converter Clutch Circuit
P0753 - Shift Solenoid A Electrical
P0758 - Shift Solenoid B Electrical
P0785 - Shift Timing Solenoid
P1860 - TCC PWM Solenoid Circuit
You can also use the search function to bring up threads where others have had one or more of these codes and possibly what they did to fix it.
With that many transmission codes, there is bound to be a common problem. The ignition switch does play a roll in things and there have been other people that have found this to be the root cause of some transmission problems.
Kilo
Jul 27, 2013 06:57 AM
abadinalbany
Apr 16, 2011 11:31 AM
bigjoewebb
Jan 27, 2009 09:36 AM
mikeesho1
Oct 26, 2007 12:31 AM
drperry
Jul 4, 2007 04:25 AM
