Go Back  Blazer Forum - Chevy Blazer Forums > Mechanical & Maintenance > Engine & Transmission
Reload this Page >
97 blazwer 4.3 engine miss wannafix it with dinomite soon please help
Community
Search
Sponsored by:
Sponsored by:
Old 10-11-2013, 08:00 PM
toyhauler1283 is on a distinguished road
OK. yes that is what I was wondering
  #32
Old 10-11-2013, 08:54 PM
Captain Hook has a spectacular aura aboutCaptain Hook has a spectacular aura aboutCaptain Hook has a spectacular aura about
If the ground doesn't end up being the problem:
If you have the trailer tow option, there's already a 10 gauge battery feed wire back by the rear bumper. Connect it to a relay and use the grey wire to trigger the relay. Then run a wire to the fuel pump from the relay. Done that a couple of times myself In theory, all you need is 14 gauge wire for that distance and amperage. A little bit of overkill never hurt a thing when it comes to wiring.
  #33
Old 10-11-2013, 09:03 PM
Cool thanks I will keep that in mind
  #34
Old 10-13-2013, 07:11 PM
I didn't have a whole lot of time today I wanted to check the positive side voltage drop and I don't know if I didn't wrong but test lead from + to dvom then to back probe of the pump and my meter didn't change it went from 12.4v to 11.9 volts till the pump shut off. But when the pump was running I did hear a lot of fuel spray sloshing sound coming from the tank I'm gonna try the relay way o hooking it up but.was curious about the sound in the tank and why my meter didn't change to show voltage drop
  #35
Old 12-31-2013, 05:26 PM
Well just an update I bought new injector pack from rock auto and installed it today runs great no check engine light. Holds fuel pressure 55psi after key is turned off
ussexplorer
09-27-2013 03:38 PM
givemesnow
08-01-2011 02:54 PM
jeffs91S10blazer
10-12-2009 07:49 PM
Tony H
12-14-2008 02:04 AM
kaercher4
21
10-13-2007 05:42 PM
Quick Reply: 97 blazwer 4.3 engine miss wannafix it with dinomite soon please help
