-   -   97 Rocker Valve Adjustment (https://blazerforum.com/forum/engine-transmission-35/97-rocker-valve-adjustment-94619/)
newguy 07-07-2017 02:16 PM
guys if it was one of the brakes sticking the rotor would be hot and you would smell it. And 84 and newer you need a cat in texas. removing it is against the law
Tynan Tha Real Dill 07-07-2017 03:27 PM
<br />I'm in Oklahoma. I removed the cat and still have the same symtoms, only a little better.
Tynan Tha Real Dill 07-07-2017 07:40 PM
1 Attachment(s)
Jumped on the highway again and got up to 55mph and it started smoking under the truck again, after I took off the cat. Got home, left it running, and video recorded the smoke. I also seen transmission fluid on the transmission pan and transmission leaking on the ground.
