-   -   97 s-10 blazer runs rough (https://blazerforum.com/forum/engine-transmission-35/97-s-10-blazer-runs-rough-9116/)
samdog21 03-04-2007 03:31 PM
97 s-10 is running rough. have replaced plugs, wires, cap and rotor. put in new fuel injector. It still runs rough and can smell fuel out of the exhaust. any suggestions?
Brian J. Lesko 03-04-2007 03:54 PM
RE: 97 s-10 blazer runs rough
Sounds like you have a bad spider valve (fuel injector). I had the same thing happen. I had to change out the unit and I needed a new EGR too.
samdog21 03-04-2007 04:05 PM
thank you
20Blazer00 03-04-2007 06:55 PM
Check all of your vacuum hoses and connections to see if they are either cracked of disconnected.
Check your EGR valve for carbon deposits, clean out passages in manifold if extremely fouled...
Check computer for DTC's to see if there is a sensor or system that is failing to provide computer with the correct data needed to run the system.
Kordog 03-05-2007 12:35 AM
When you say you put a new fuel injector in, do you mean the whole assembly of 6 injectors, or just one for one cylinder? Also check the compression, and do you have a check engine light?
