98 blazer 4x4 in and out of overdrive
Well I've had my blazer for about a year now and ever since I've had it is has always done this.
Going down the freeway when truck is at normal temp it will kick out of overdrive if I let out of the gas a little, but as soon as I push back down on the gas it will go back in untill I let off again.
I can't seem to figure out what is is, can someone help me please? Thank you.
Watching the rpm go from 2k up to 3k then back down. I can shift it into 3rd and the rpms only go up a little. I also have 2 codes coming up, 1 for evap emission control system vent circut, and 2 bank 1 sensor 3 o2. I don't know if either of these have anything to do with it but ill put it out there.
The TCC solenoid in the pan could have an affect on this, however, it should set a code.
You may want to consider getting it looked at by a few different transmission shops. With a scan tool, you can monitor the torque converter. Transmission shops should be able to do this as well as monitor other things pertinent (line pressure, etc) to the occurrence.
I say that the TC may be going out because it shouldn't allow that much of a rise in RPM.
Are your brake lights working properly? One thing just occurred to me. If the brake switch closes, it will cause the torque converter to unlock.
