99 4.3l cylinder head sequence
I am working on a 99 4.3l with a bad head gasket. I have the IM off and am ready to remove the valve covers and the heads. Does anyone have the sequence for removing and installing the heads as well as the torque specs. I understand the installing part is done in two or three passes.
Thanks in advanced. |
It seems I found it
https://blazerforum.com/forum/2nd-ge...equence-40812/ I guess I needed to search a little better. ;) |
| All times are GMT -5. The time now is 09:54 AM. |
