99 4x4 4.3L suspected issue with OD
Old Jan 6, 2012 | 12:46 PM
junyo's Avatar
junyo is on a distinguished road
Default 99 4x4 4.3L suspected issue with OD
Been having a drivability issue with my 99 4x4 4.3L Blazer. Light shuddering/hesitation, mainly between 40-50 mph. Getting worse the last couple of weeks. Was thinking it was misfires but my mechanic tells me he sees no codes. So did some research, asked my brother, who's a decent shadetree mechanic and used to have a 96; now the hypothesis is that the OD is engaging/disengaging erratically. My brother suggested a test consisting of driving it in 3, thus locking out OD, and see if I still see the problem. I tried that and the problem didn't recur.
Questions:
1. Does this diagnosis make sense?
2. Is the test valid?
3. Are there any further simple diagnostics I can attempt to confirm or disprove the theory?
Assuming # 1 above is true, my research indicates that potential causes of the OD hunting would be:
1. Throttle Position switch/sensor
2. Solenoid(s?) that actuates the OD
3. Vacuum leak
4. Torque Converter
5. Transmission else, aka worst case scenario
Does that list look correct, is is there something else I should be looking for?
Lastly, if the diagnosis and the list of potential problems is correct, what's the best/most cost effective order in which to work through the list? For instance, I should simply be able to test the TPS with a multimeter, correct?
I'm not a mechanic, so I'm basically regurgitating stuff I've heard/read, so apologies if my terminology is wrong or I've completely missed the mark.
Old Jan 6, 2012 | 05:45 PM
trucktom's Avatar
trucktom is on a distinguished road
torque converter shudder is common although not with gms or this unit. happens when friction modifiers in fluid get used up, usually cured by a thourough service. the 4l60e does have a common valve body issue that does cause the converter to slip but this doesnt sound like ur case plus u would get a code. the fast easy test is go to a auto parts, ask for trans additive called lube guard, u want the red bottle. pour it in and drive within a mile if its shudder this will fix it dead, no bs been around for a long time its not solvent or goo just additive replacement. i would also be suspect of a rear u joint. u can try to explain ur test results better, as to in 3rd were u at the ''happy'' speed'' of problem and is it load sensitive at that speed
Old Feb 10, 2012 | 02:38 AM
stanitis's Avatar
stanitis is on a distinguished road
Arrow
I would also suspect/include in diagnosis, the torque converter lock up as a possibility. I had my 4l60e around 45-50 mph seemingly "popping" in & out (back & forth) of gear('s) while in "OD". I put in a transgo HD 2 shift kit, sonnax .500 over boost valve, corvette 2nd servo & a sonnax 3-4 servo & pin, pinless 1-2 & 2-3 actuators, pressure regulator & wiring harness (combined). I have had no problems since. As a precautionary procedure, I also put in "shutter guard", comes in a packaged long skinny red tube. Oh, I also used a new valve body plate (did the performance drilling) & used the nylon check ***** instead of re-using the metal ones as too guard against premature plate wear as the metal ***** do wear on the plate! My first shift kit install, took my time, paid attention, "hated" fumbling with the check *****, did the recommended shift stem (internal part) grind as recommended to releive some of the "reverse/drive slide bump". All has been well for over a year now, & second gear hits like a camaro, easier on clutch wear!
brian79z
32
Feb 23, 2015 07:13 PM
99bblazer99
Jun 15, 2013 08:38 PM
J.R. Clay
Mar 16, 2011 12:33 AM
camino88
Jan 7, 2010 12:51 PM
extreme
Jan 5, 2010 07:29 AM
