-   -   99 Blazer - Major Leak (https://blazerforum.com/forum/engine-transmission-35/99-blazer-major-leak-90306/)
xXPurpleDogXx 07-24-2015 09:36 PM
2 Attachment(s)
Hey guys, I have a major leak coming from my 99 blazer I believe it's either the radiator or water pump. My anti-freeze tank goes from full to empty within a few hours of driving. It's obviously leaking because when I park, there is 6 or 7 spots where water is leaking (I believe the pump may be leaking water onto the fiberglass panel at the bottom of the car underneath the engine and it's pouring out from all sides. Any advice or suggestions?
odat 07-24-2015 09:55 PM
remove the fiberglass skid pan and look, most just bolt in with less than a dozen bolts
xXPurpleDogXx 07-25-2015 11:57 AM
I found the leak, it was coming from the metal piping on the right side of the radiator right underneath the hose. Thanks for the help
96BlueBlazes 11-02-2015 07:39 PM
That's good news. I'm glad it wasn't your water pump. I'm looking around on the forum because I've sprung a leak. It's spraying coolant and steam, sounds just like a pin prick in a water pipe. I'm glad it's not leaking like crazy but I'm not driving it till I find the leak. Once again I am disappointed by the fact that I don't have a air ratchet to remove my metal plate and a hydraulic car lift.
