-   -   99 blazer starting problems (https://blazerforum.com/forum/engine-transmission-35/99-blazer-starting-problems-39789/)
Bootyjones Jan 25, 2010 09:40 PM
Hi, I purchased a '99 Blazer last year ans since then have replaced the transmission, fuel pump, distributor cap, starter, battery, spark plugs, and just today the ignition coil. I have had it running although recently it hasn't been, the reason I replaced the ignition coil today is it won't start. It starter cranks, the fuel pump is good, but it won't fire at all. When I shut the key off it diesels for a sec. but that's it. Any suggestions.
sparky672 Jan 25, 2010 11:33 PM
Back to basics, right? Fuel, Spark, Compression, etc...
Have you pulled out a plug and checked to see if there's a good spark when you crank?
Bootyjones Jan 26, 2010 10:39 PM
reply to sparky
I just tried removing a plug and seeing if it sparks, which it doesn't, I'm going to take the battery in to get a new one tomorrow because I think it might be causing some issues. If you have any other thoughts please let me know.
sparky672 Jan 27, 2010 09:36 AM
If the battery is strong enough to crank the engine over then you should be getting a spark.
You said you changed the coil & distributor cap. Stupid question... did you replace the rotor too?
Are all the wires and connectors in place? Are the spark plug wires good?
hubert hefner Jan 27, 2010 10:31 AM
you might check the ignition module also.
dsrp Jan 28, 2010 02:32 AM
check pick up coil and wires if you ave fire from the pick up coil your distributor might be the problem,
Bootyjones Jan 29, 2010 08:58 AM
Its alive
So after replacing the battery it starts without fail. I wasn't sure if that would fix it because I bought a battery for it last year but it works. Thanks for your tips.
Bootyjones Feb 9, 2010 06:09 PM
More issues
So now my Blazer sometimes stalls after idling for a few minutes, then afterward won't start. Any thoughts?
