| LowLife |
02-19-2011 08:39 PM |
well there should be a timing mark on the crank and cam gears the cam mark should be in the 6 o clock position and the crank should be 12 o clock position to line up correct, it is possible to of jumped the timing if your chain has enough play in it. in order to change the timing chain you need to remove the water pump, i do it with the fan still connected to the pump but some take it off, unplug the crank sensor, remove the timing cover, unbolt the cam gear, take off the timing chain, use a puller usually a 2 arm puller works for me to pull the crank gear off then tap the new lower gear on, bolt the cam gear on with the new chain in place then throw your timing cover back on
