-   -   99 LS Blazer timming (https://blazerforum.com/forum/engine-transmission-35/99-ls-blazer-timming-96705/)
MadMerritt 04-15-2018 04:12 AM
Gday all :icon_toast:
How do i check the timming on my 4.3ltr Blazer? Do i set it like a normal engine or is it computer controlled?
All advice is hugely appreciated :icon_toast:
newguy 04-15-2018 05:53 AM
All timing is computer controlled, It cant be advanced. You need a high end scanner to do a crank position relearn if needed, that is basically adjusting your timing then do a camshaft position set Which adj. rotor to contacts on the cap.
MadMerritt 04-15-2018 05:58 AM
Oh ok, well that sucks...
i know not to play with it now hahaha
newguy 04-15-2018 06:15 AM
Yes, dont move anything with the dist. You`ll create misfires
