-   -   Abs and emergency brake lights (https://blazerforum.com/forum/engine-transmission-35/abs-emergency-brake-lights-99977/)
Skinnykenny 07-28-2019 12:11 PM
I have a 2002 blazer. Every so often the abs and the emergency brake lights come on at the same time. I put it on the scanner but it doesn't show any codes. I was wondering if anyone else has had this issue and if they found out what the problem was.
bigheartedchilly 07-28-2019 04:02 PM
That's a possible ABS module failure which can be "repaired". You can check this thread for a bit of info, or do a search on the forum for further ideas/solutions, loads of it on here regarding the issue.
Skinnykenny 07-29-2019 04:10 AM
Thanks I will.
bigheartedchilly 07-29-2019 07:32 AM
I had one do the same thing on a different blazer I had, pulled the abs computer unit and fixed it up like the video shows in the link. Worked perfect afterwords... good luck :)
