Acceleration and shifting issues
Old Mar 23, 2011 | 08:16 PM
  #21
ski9600's Avatar
ski9600 is on a distinguished road
Originally Posted by Hanr3
To both of you with problems.
Pull the tranny dipstick and smell it, does it smell burnt, if so your tranny is toast.
Is the fluid red or black, red =good, black = bad.
Now onto the more realistic problem, with a little background. The computer controls the engine and tranny as one unit. It reads various sensors and makes adjustments to the engine and tranny shift points based on those readings. 9 times out of 10 when people report tranny problems its not really the tranny malfunctioning, its the engine. If you have either of the above conditions, burnt dark/black tranny fluid your in the 10th category.
The biggest problem with engine performance as you discribed is either a faulty ignition system (typically the distributor cap) or leaking spider injector assemble, another posibility is vacuum leak (vacuum hose or intake manifold).
One of those is typically the culprit, after that we get into things like EGR, MAF/MAS sensor, etc. Do you have an aftermarket air filter, like a K&N? Those things a natorious for depositing oil on the MAF/MAS sensor and causing all sorts of engine/tranny performance issues.
The key here is the moisture. If your truck runs better when its raining, typically that means you ahve a crack in teh distributor cap. The other option is you have a lose electrical connector on the tranny. Look for the wire pig tail on the passengers side towards the back, unhook it and make sure its dry, then reconnect it.
To check for a vacuum leak use a spray can of either, spray it around the engine compartment while the engine is running, if your rpms go up, you found a vacuum leak. False air is another posibility, false air is air that gets in the intake manifold by a means other than through the MAS/MAF sensor, like if the intake hose is disconnected or cracked by the intake manifold. The computer wont be able to compensate for tha false air and it causes performance issues.
As for the downshifting, nothing wrong with it like Kyle pointed out. The tranny has an overrun gear, when you down shift the tranny will spool up until it matches vehicle speed and then start to decelereate. And no you cannot get your tranny to shift gears while going too fast, you may be able to move the lever, however it wont downshift. As for upshifting, it wont shift any higher than you go with the shift lever. However you can blow up your engine downshifting too soon, or upshifting too late. Wathc those RPM's, that pretty red line isnt just a cute color to break up the look of hte dash!
Thses are not high reving engines, they gain most of thier power under 3,000 rpms. In most cases under 2,500 rpms. Sure red line is like 4-5K, however itll be sreaming bloody murder at those rpms.
I hope that helps.
Great post. I've just joined the forums because having similar troubles right now and thankfully the tranny fluid is red, proper level and doesn't smell. I'm getting no SES light, but sure enough there was 3 codes tonight. Two were for O2 sensors, and the 3rd was MAF sensor. We cleared the codes and drove up the pass (I live at 9600' altitude and we drove up to about 10000') and when we got back sure enough there were more codes (three all for O2 sensors) but still no SES light. I will clean the MAF, search for vacuum leaks tomorrow night and also check the fuse for the transmission underhood. Thanks again, Ski /btw, 2000 Blazer 4dr LT Blue, named Debbie
Old Mar 23, 2011 | 09:57 PM
  #22
Hanr3's Avatar
Thanks.
Welcome.
Which pass? I used to live in Frisco, CO. Elva. 9100.
Good luck with her.
Old Mar 30, 2011 | 07:23 PM
  #23
ski9600's Avatar
Thanks.
Welcome.
Good luck with her.
Well, we cleaned the MAF sensor (wasn't dirty) and tonight replaced all 3 O2 sensors and that has solved my TRANSMISSION problem. Thanks for all the stuff here!
Old Mar 30, 2011 | 09:03 PM
  #24
Hanr3's Avatar
Your welcome.
Yet again, another tranny porblem solved and the tranny had nothing wrong with it.
Glad we could help.
Old Mar 31, 2011 | 08:34 PM
  #25
ski9600's Avatar
Your welcome.
Glad we could help.
Yep, really happy to be driving in "closed circuit" mode now. Took a short trip today and it really feels much better. The "torque reduced" or "limp home" mode is how I've been driving for as much as 3 years.
The one thing I wish I could change is that if there's a fault with the O2 sensor that the SES light would come on.
I wasn't the purchaser of this vehicle and couldn't tell that it was on the open circuit/torque reduced (80%) mode, codes in memory, and just thought the fuel economy sucked and the vehicle didn't have enough HP/torque.
Now I'm kind of stoked to do something else like a cold air intake and chip mod. I'll search around to see what might be best for my little Chevy Debbie
If the SES light had been on I would've had it fixed a long time ago, and at my altitude it makes a really huge difference (between 5500-11000ft).
Old Apr 2, 2011 | 04:27 PM
  #26
briancarswell's Avatar
briancarswell is on a distinguished road
Default Code tcc
1997 blazer 4 wheel drive 4.3 engine
Transmission won't go into 3rd gear or overdrive
Please help any ideas?
Old Apr 2, 2011 | 04:31 PM
  #27
Burnt up 3-4 clutch pack? You may want to create your own thread after searching the forum and looking at the common 4L60E problems thread in the Tech Article (DIY) section.
99EnvoyBravada
Dec 1, 2013 11:13 AM
terry s
Feb 12, 2013 08:30 PM
tdbone1
Dec 20, 2012 09:40 AM
oisinirish
Sep 27, 2009 10:04 PM
96jimmy4x4in
Oct 7, 2007 09:23 PM
