-   -   Acts like it's out of gas. Won't start! (https://blazerforum.com/forum/engine-transmission-35/acts-like-its-out-gas-wont-start-95970/)
'93BLZR 12-23-2017 12:37 PM
Okay, this morning was the morning I was supposed to get the blazer of the trailer. Some 5 year old gas is in that tank, so before I ran it, I put some stabilizer in the tank. It ran fine the past few days while I was trying to run the old crap out. This morning when I went to start it up, it was very hard to start, but ran like crap for a few seconds. Now it fires several times but won't start. Occasionally there is a backfire. Cleaned the throttle body and still won't start. I also put about. 2 gallons if fresh gas in. Really annoying. I've always worked on carbed cars so I don't know enough about EFI. Fuel pump runs just fine. Help please!
'93BLZR 12-23-2017 12:41 PM
christine_208 12-23-2017 12:47 PM
Does the gas stabilizer you used also absorb water? Could there still be water in the tank/lines?
Could the stabilizer have loosened up any gunk in the tank which then clogged the filter?
'93BLZR 12-23-2017 12:48 PM
All the stabilizer does is absorb water and balance the octane in the old gas. I don't know where the fuel rail is to test pressure.
christine_208 12-23-2017 01:10 PM
I once had a '92 Vortec and I'm pretty sure I checked the pressure on mine at the supply fuel line where it came up over the rear end of the engine block and before it entered the lower intake manifold.
Freeze the frame of this video at 4:24 and you can see the fitting that I'm recalling.
christine_208 12-23-2017 01:13 PM
Schrader valve for checking fuel pressure.
https://cimg8.ibsrv.net/gimg/blazerf...630c9dd515.jpg
'93BLZR 12-23-2017 02:14 PM
Thanks!
'93BLZR 12-23-2017 03:07 PM
Okay, I have some fuel pressure I use the screwdriver to pump down a little Schrader valve and I got to spread of gas out if I hold the valve down and turn on the key yes brings out as well although there's not that much. I don't have a fuel pressure gauge so I don't exactly know how to test how much pressure there is. It's just a little Spurt of gas not much
christine_208 12-23-2017 04:08 PM
I don't have a manual that covers 1993 but my Chilton 1994-2004 manual says that for the Central Multiport Fuel Injection System (CMFI) with the key On and the engine NOT running, the pressure should be 58-64 psi. With the engine running at idle, the pressure should decrease by about 3 to 10 psi.
FYI: According to my manual, the CMFI motors in 94 and 95 were the ones that had the cool intakes with the cool swoopy runners and the plenum cover that said Vortec.
Maybe you can rent one of the fuel injection pressure tools from a local shop? I bought one when I had to diagnose and then replace the fuel injection spider in my 1992.
Also, having sat for so long, were you going to change out the fuel filter anyway? If you were, perhaps you should do it now just in the off chance it is the culprit?
'93BLZR 12-23-2017 04:17 PM
Any idea where it is? I will change the filter if I could find it :D
christine_208 12-23-2017 05:00 PM
If I remember correctly, it is mounted along the inside of the drivers side frame rail about midway between the tires; about where the rear of the door is.
Be sure the pressure is released in the fuel line system and be ready to have up to several cups of gas drain out. Depending on the type of fittings there you can cap or plug them with things you have around the shop; golf tee, vacuum line cap.
I think even on my 92 there were quick-connect fittings for the lines. Once you get a replacement filter you should be able to see how to get them apart.
What I remember is that getting to the mounting bracket was not so much hard as annoying. LOL
'93BLZR 12-23-2017 06:50 PM
Ok, I've officially spent 4 hours trying to get the stupid oil filter off. I wanted to change the oil before i did much with it. I'll also put some Marvel Mystery Oil in the crankcase and gas tank, but I will check for the fuel filter tomorrow. Once this is all said and done and it runs again, I have to fix the hanging transfer case and leaky trans.
