Acts weird when it rains!!
Ok here's what I'm having, recently especially when it rains, my blazer shifts kinda weird... not really shifting but it justfeels, you know that feeling when the car shifts between gears, and it does it between 0 and 45 mph... feels like gas isn'tkicking
I've recenlty had a fuel pump installed, and couple days later my check engine light came on and it was my O2 sensor, I didn't change it anda week later the light went off!! Any suggestions? |
RE: Acts weird when it rains!!
I would take a look at your ignition components (cap, rotor and wires) real close like. Go out at night and mist the engine with water (spray bottle on a fine mist) with the engine running. If you see sparks jumping to ground, then you have bad wires.
When was the last time you did a tune up? |
Back in octobor 07 I did everything rotor, cap, spark plugs andwires... changed my pcv valve and had a new fuel filter all done bydecember 07.
Tell you the truth, it feels a little bitthe same before I replaced my wires, plugs, cap and rotor!! but why?? |
What brand of parts did you use?
I would pop the cap off and check for carbon trails on the pins inside as well as carbon buildup on the tip of the rotor. Being humidity dependant points a big finger at the ignition system. |
a mechanic suggested that my cap could be lose or untightend right... I checked it today and it seems pretty tight to me, wires are all tightin places!!
ORIGINAL: yazan84 Ok here's what I'm having, recently especially when it rains, my blazer shifts kinda weird... not really shifting but it justfeels, you know that feeling when the car shifts between gears, and it does it between 0 and 45 mph... feels like gas isn'tkicking I've recenlty had a fuel pump installed, and couple days later my check engine light came on and it was my O2 sensor, I didn't change it anda week later the light went off!! Any suggestions? |
I also have the same issue. I think It's pretty common for these. I have a 96 4x4
ORIGINAL: yazan84 Back in octobor 07 I did everything rotor, cap, spark plugs andwires... changed my pcv valve and had a new fuel filter all done bydecember 07. Tell you the truth, it feels a little bitthe same before I replaced my wires, plugs, cap and rotor!! but why?? A lot of people on here suggest only using AC Delco parts for ignition components. Hope this helps. |
One thing that has cropped up from time to time here is a plugged screen at the bottom of the distributor that may cause condensation under the cap. If this is the case, then it really wouldn't matter what you are using for ignition components as your misfire could be happening inside the cap given the right conditions. Something else to look into.
I would definitely put this screen on the 'usual suspects' list.
