Aftermarket gauges
Alright i have a 1985 s10 blazer 2.8 v6 and cant find where to put a aftermarket oil pressure and water temp gauge...any ideas thx
RE: Aftermarket gauges
On theA pillar (the one that goes up from the dash to the roof). Check Summit or LMC for the pod.
Srry guys guess i should have made it a little more clear i cant figure out where to hook up the oil pressure gauge to the engine got the temp just fine thx and srry
Do you have the factory gauges and keeping them, don't have them, aint keeping them?
The factory one hooks up right above the oil filter in the adaptor/block (depending). If your got the factory gauge and keeping it working you can get a t at any hardware store and just install it. if you aint got the factory gauge there should be a plug in the above location. if you got it and don't care you can just unhook the factory sender and screw your new one in (might need an adaptor) |
| All times are GMT -5. The time now is 06:15 AM. |
