-   -   another 4.3 running like crap (https://blazerforum.com/forum/engine-transmission-35/another-4-3-running-like-crap-74034/)
red99zr2 09-25-2012 02:25 PM
i just picked up a 99 zr2 blazer, has a miss when i bought it... really bad, was sitting for a couple months, the guy didnt have money to put into it so i picked t up fairly cheap... has 170xxx miles, got it home, did normal stuff, cap, rotor, coil, plugs, wires, fuel filter.. fixed acouple vacuum hoses. ran better but not perfect... ran a compression test all cyl. between 115 -125 psi.. ran a fuel pressure test, just key on goes up to 62psi.. at idle bounces between 52-56 psi.. i replaced the spider with new updated version... runs better but still stumbles and misses... mostly under medium throttle between 1500-2100rpm and at idle... not sure what else to do ... i removed the cat. and gutted it.. had code p0300 for miss fire, cleared it out light hasnt been back on... had a code p0452 evap pressure sensor signal low/ short... cleared hasnt come back.. also when i take fuel tank cap off it releaves pressure.. none of my other s10s have done this.. any help would be great!!! thanks for your time...
50lb_cat 09-25-2012 02:41 PM
What brand did you use for the tune up? Have you cleaned the MAF sensor? Usually a random misfire is always do to secondary ignition componets.
red99zr2 09-25-2012 05:13 PM
Accel cap,rotor,coil... duralast wires...ngk plugs...cleaned maf already
richphotos 09-25-2012 05:43 PM
These things only like ACdelco cap, rotor, coil and wires.
xgiovannix12 09-25-2012 06:08 PM
Ngk plugs do well in these motors
red99zr2 09-25-2012 06:28 PM
Thats what i have been reading, but i dont see how it would effect it... accel stuff has to have better fire than acdelco..only down fall i bought would be duralast wires
Jase1979 09-25-2012 06:38 PM
I took a brand new cap out of the box installed it on mine and chased a cylinder #1 missfire for 3 weeks before I listened to this forum and brought a delco cap, The forum was right! cap was the issue, and visually the other cap looked perfect
red99zr2 09-26-2012 02:47 AM
i will do alil more digging if nothing else looks like ill start buying parts again... kinda sux if i have $150 worth or parts i cant use..
mmmrodge 09-26-2012 06:51 AM
clean the EGR valve?
red99zr2 09-26-2012 11:24 AM
swapped it with one from a spare engine i have no change
