-   -   Another fuel pump failure (https://blazerforum.com/forum/engine-transmission-35/another-fuel-pump-failure-97876/)
don james 10-03-2018 07:55 PM
I was cruisin the colorado mountains today, looking at the colorful aspens..........down the hill i went and NOT UP........fuel pump apparently died on the way down??...........Of course there is no cell coverage and the houses in the area had all of the land lines wiped out in a flood after a fire......luckkily a county sheriff happened buy and called in a tow..........
I beat on the tank and could not get any sound at all from the pump........I will try to check the fuses.........[not sure witch ones???]..........I have not had any clue the pump was near death.......
It has 144k on it probably the original pump.
...........so witch pump ACDELCO MU1733 DELPHI FG0052 {#19177220, 25176789, 25344818 DELPHI FG0287 {#19179591, 25347147} ..........I'll do some research, but i f anybody wants to suggest the best for my 2001 4 door. I would appreciate the knowledge ........
GreenBlazer2002 10-06-2018 08:11 AM
AC delco is OEM. Stick with it. Look how long the first one lasted. 👍
don james 10-06-2018 09:19 AM
ac mu1733.....should be here today..........yep that's what came out..........thanks........
odat 10-06-2018 11:22 PM
Last few AC Delco and Delphi pumps that I have installed for people were like all the rest - { MADE IN CHINA}
don james 10-07-2018 08:00 AM
I will look a little closer at this one..........It actually looks, as well or a little better than the original.............but looks AINT everything, are they..............I should have it running today.............I don't have a clue why acdelco decided to change the wiring connector............??
