Attaching torque converter plate to tranny
Ok quick question, Recent pulled my engine due to major oil leak in the oil pan, got new gaskets, rear main and front timing cover.
What I forgot to do in accordance of pulling the engine was mark which hole matches with which from the tranny to the torque converter plate, and I turned the engine over a few times when it was out of the engine bay so im not quite sure which hole lines up with which. My question is does it even matter? and if it does then whats a good sign to tell which bolt hole lines with what one? Aswell I tried looking up torque specs for torque converter and cant find it anywhere, They were hell to get off so im guessing that its a very high torque spec? |
It is not necessary to get the holes to match up exactly where they were before.
My references state 46ftlbs for the bolt torque. |
awesome thanks swart
| All times are GMT -5. The time now is 09:29 AM. |
