Backfiring internally and sputtering
I have a 1999 chevy blazer with the 4.3 vortec. I have changed the distributor cap, plugs, plug wires, fuel pump. Cleaned MAF, Throttle body, EGR. My problem is that it starts sputtering during normal driving especially after driving a few miles. It also has some internal backfiring in the engine sometimes when I pull out on the highway. My rpm's fluctuates a couple thousand rpm's from about 2100 to 1900 rpm's at normal driving. Also, the thermostat gauge fluctuates from around 160 to 100 in sequence with my rpm gauge. Im getting very poor gas mileage. Any ideas before dumping a bunch of money in a problem I've seen other people keeping changing everything before realizing all the money they waisted. Any help will be gladly appreciated.
Did you have this problem before you changed your cap? If so then I would say probly get your timing checked out. If the problem didn't come till after then it might be a bad cap and arching across terminals, I've had that happen once with a brand new cap on first start up.
gagirl320
Aug 7, 2010 10:10 AM
Iceman_19
Aug 26, 2009 03:14 PM
grendragginbu
Oct 11, 2007 04:32 PM
infamous
Jan 7, 2007 04:18 AM
