-   -   Bell Housing to engine block struts (https://blazerforum.com/forum/engine-transmission-35/bell-housing-engine-block-struts-24700/)
fondo 11-08-2008 11:32 PM
Can anyone tell me how I can re-fasten the driver side strut to the engine. I had to take it off to remove/install new oil lines. Now I can't get the bolt to line up and thread in. Any suggestions. Also, can I drive the vehicle a very short distance without one of these stuts attached or will something break. Thanks
Blue95Blazer 11-09-2008 10:09 AM
RE: Bell Housing to engine block struts
Hi I removed the driverside motor mount bolt than I jacked up the engine (It will lift up a few inchesjust enough) I used A 9/16 universal and a few extensions through the wheel well to replace the bolt , And I have driven a few trucks with themmissing and never incured a problem Hope this helps
Eric G
