Blazer 1977
Blazer 1977
Hey every one. i have a Chevy Blazer 1977 Full Size, and i am trying to rebuild it. i am looking for the instruction manual or technical repair manual of this car, but i have not found it on the web, yet. can anyone help me through this? |
RE: Blazer 1977
I'll see if I can find an address of a company that supplies original manuals. This could take me a week or so.
Is there any repair that you are needing help with right away? |
RE: Blazer 1977
Dearest Chevy Lover,
thank you for your message. actually, I live in Persia (Iran), so preparation of stuffs are not really easy. however, my car has no technical problem which be really troublesome. i have some questions, if you could: 1- in my car, when it is not locked (auxhiliary gearbox), the speed of each wheel is different. as i read in 77 Chevy Blazer Brochure, it is ideal for low-traction and normal-traction surfaces. does it mean that the force and the torque of the engine and differentials transmitted to the wheel which has the most friction to the road? in other words, does the wheel turns that is the hardest one to turn??? 2-the bad thing about my car is that almost none of its inside systems, such as automatic air-conditioner, lock light on the dash (which shows if the gearbox is locked or not), handbrake light (or foot brake!!!), seat belts light, engine and oil check lights are not functioning properly or some doesn't work at all!!! how can i fix them??? is there any plan or detailed manual for it??? 3-under the dash board, on the right side, there is a small hatch, that whenever the air-conditioner is set to a specific system, the hatch starts opening slowly. what does this hatch do??? special thanks BENZIN |
RE: Blazer 1977
eBay may or may not be an option. CLICK HERE for '1977 blazer manual' search results.
| All times are GMT -5. The time now is 12:14 PM. |
