-   -   blazer stuck in park wont shift (https://blazerforum.com/forum/engine-transmission-35/blazer-stuck-park-wont-shift-51330/)
1997 red chevy blazer 11-08-2010 02:55 PM
my blazer is stuck in park and it will not go into reverse/drive etc what would be the problem before i get it towed to a shop and when i try to push the button in it makes a clicking noise from the dash
bouts5991 11-08-2010 04:48 PM
could be the linkage from the steering colum to the tranny, either bound up, could of been thrown into park and the linkage pushed back a little to far, and its locked that way.. do any offroading recently? could be a stick stuck up in there.. may also be rusted solid... or a piece of rust stoping your linkage from moving..
could also be the tranny its self. how many kms on the truck, i dont think that if it was working one day and not the next the tranny its self would the issue. its probably linkage
the 4x4 gears, now depending on the year. if im not right, 4x4 wont go into 4x4 if its in park? im pretty sure, and i know on mine forsure (93), it has to be in neutral to put it in 4x4, now theres shift on the fly, but i think that only goes for driving forward. that i not 100% sure about. but there is soooo many possible things that could be wrong but atleast theres a start..
swartlkk 11-09-2010 06:40 PM
Park interlock solenoid. Sounds like it is not properly disengaging.
69chevelle 11-09-2010 08:04 PM
do your brake lights come on? some vehicles(not sure on the blazer) the 'Park interlock solenoid' as kyle calls it :) engages with power off the brake switch...
correct me if I'm wrong
and are you on a hill? try rocking the truck a bit, if you are on a steep incline try pulling your truck up a hair to take the force off the park 'pin'
jkhabel 12-21-2010 06:10 PM
i have a 1997 chevy blazer Ls.....just recently my truck just died while i was driving.....the truck will not start but the motor will turn over....when you turn the key to the ACC position, it doesn't get any of the dash lights, like the check engine light, the brake light, seat belt etc....it also wont come out of park even if you have your foot on the brake and the key turned....as soon as the dash lights went out it got stuck in park
swartlkk 12-21-2010 06:13 PM
jkhabel, your problem sounds more like an ignition switch failure than the park interlock solenoid.
jkhabel 12-22-2010 09:20 AM
blazer in park
Thanks swartzs! That's what conclusion we came up with also.
ChevyFamily 01-23-2011 10:28 PM
jkhabel, what ended up being your problem? I changed my brakes today and then when I went to go for a test drive I couldn't get it out of park.
jkhabel 01-24-2011 06:57 AM
The ignition switch is going bad.
ChevyFamily 01-24-2011 12:12 PM
jkhabel, thanks for replying. I am wondering what the symptom you were having. I disconnected the transmission linkage under the car and I can freely switch the trans into any gear with the lever on the trans. My Servo that releases the console shifter isn't working and the linkage cable seems stuck. Were these problems you had with a bad ignition switch?
jkhabel 01-25-2011 07:04 AM
These were my symptoms: the truck will not start but the motor will turn over to the on position....when you turn the key to the ACC position, it doesn't get any of the dash lights, like the check engine light, the brake light, seat belt etc.... but my headlights and radio worked fine. It also wont come out of park even if you have your foot on the brake and the key turned....as soon as the dash lights went out it got stuck in park. But now if I don't get any of the dash lights. I'll leaceit on tha "ON" position for a coouple of seconds and might dash and lights will come on. I found this out by keep playing with the ignition key.
ChevyFamily 01-25-2011 01:35 PM
Gave up and took it to the dealer. Going to be $540 to replace the linkage cable from the shifter to the trans and to find and repair a broken wire somewhere that is preventing power from making it to the BTSI switch. Suck.
millford 01-25-2011 04:06 PM
It might be too late but I had the same problem and it was only a blown fuse,actually it was the signal fuse.Dont know if you checked this out.
camero 06-10-2012 05:54 PM
i have and 03 blazer zr2 and it is stuck in park. please help
it will start but can not get it out of park.
ChevyFamily 06-11-2012 08:12 PM
Mine ended up being the linkage cable connecting the transmission from the shifter and a short in the cable that runs to the little servo that allows you to take it out of park. You can get underneath and unhook the linkage cable from your transmission and try to manually shift it. Be sure that it is secure before you put it in gear so you don't roll over yourself. If you can shift it manually then it is possible that your cable has failed as mine did. Good Luck.
camero 09-14-2012 06:51 PM
it was a broken wire in console
jkhabel 09-15-2012 08:24 AM
97 Blazer won't come out of park
Originally Posted by chevyfamily (Post 401579)
jkhabel, thanks for replying. I am wondering what the symptom you were having. I disconnected the transmission linkage under the car and i can freely switch the trans into any gear with the lever on the trans. My servo that releases the console shifter isn't working and the linkage cable seems stuck. Were these problems you had with a bad ignition switch?
ignitioi\n switch is bad
jkhabel 09-15-2012 08:25 AM
iGNITION SWITCH IS BAD
R007 01-21-2014 04:41 PM
My 1999 Chevrolet Blazer was stuck in park a few weeks ago. It turned out to be a broken wire (black/ground). So my recommendation is to have a look at the wires connected to the solenoid near the shifter.
