-   -   blazer stuck in park wont shift (https://blazerforum.com/forum/engine-transmission-35/blazer-stuck-park-wont-shift-51330/)
jkhabel 01-25-2011 07:04 AM
These were my symptoms: the truck will not start but the motor will turn over to the on position....when you turn the key to the ACC position, it doesn't get any of the dash lights, like the check engine light, the brake light, seat belt etc.... but my headlights and radio worked fine. It also wont come out of park even if you have your foot on the brake and the key turned....as soon as the dash lights went out it got stuck in park. But now if I don't get any of the dash lights. I'll leaceit on tha "ON" position for a coouple of seconds and might dash and lights will come on. I found this out by keep playing with the ignition key.
ChevyFamily 01-25-2011 01:35 PM
Gave up and took it to the dealer. Going to be $540 to replace the linkage cable from the shifter to the trans and to find and repair a broken wire somewhere that is preventing power from making it to the BTSI switch. Suck.
millford 01-25-2011 04:06 PM
It might be too late but I had the same problem and it was only a blown fuse,actually it was the signal fuse.Dont know if you checked this out.
camero 06-10-2012 05:54 PM
i have and 03 blazer zr2 and it is stuck in park. please help
it will start but can not get it out of park.
ChevyFamily 06-11-2012 08:12 PM
Mine ended up being the linkage cable connecting the transmission from the shifter and a short in the cable that runs to the little servo that allows you to take it out of park. You can get underneath and unhook the linkage cable from your transmission and try to manually shift it. Be sure that it is secure before you put it in gear so you don't roll over yourself. If you can shift it manually then it is possible that your cable has failed as mine did. Good Luck.
camero 09-14-2012 06:51 PM
it was a broken wire in console
jkhabel 09-15-2012 08:24 AM
97 Blazer won't come out of park
Originally Posted by chevyfamily (Post 401579)
jkhabel, thanks for replying. I am wondering what the symptom you were having. I disconnected the transmission linkage under the car and i can freely switch the trans into any gear with the lever on the trans. My servo that releases the console shifter isn't working and the linkage cable seems stuck. Were these problems you had with a bad ignition switch?
ignitioi\n switch is bad
jkhabel 09-15-2012 08:25 AM
iGNITION SWITCH IS BAD
R007 01-21-2014 04:41 PM
My 1999 Chevrolet Blazer was stuck in park a few weeks ago. It turned out to be a broken wire (black/ground). So my recommendation is to have a look at the wires connected to the solenoid near the shifter.
