Go Back  Blazer Forum - Chevy Blazer Forums > Mechanical & Maintenance > Engine & Transmission
Reload this Page >
Blazer will not start, I'm at a loss!!!
Community
Search
Sponsored by:
Sponsored by:
Old 09-13-2011, 08:27 PM
Gmas95 is on a distinguished road
Can be lots of things unfortunately , Try checking spark from all 6 wires, Can just pull one plug then hook it to each wire.
Check to see if the plug smells like gas also, is wet or has black soot on it.
Old 09-13-2011, 08:32 PM
monkey36 is on a distinguished road
Ok, I will try that tomorrow along with kicking the gas tank and trying to rent a gauge to read my fuel pressure. I will let you all know how it works out.
Old 09-13-2011, 08:56 PM
Make sure you slightly kick it, dont got doing any more damage
Old 09-14-2011, 11:01 AM
This sounds exactly like my issue, could this be my problem?
https://blazerforum.com/forum/2nd-ge...o-start-28385/
Ok guys, she's alive again. As you'll see in my previous post after searching last night for hours!!!! I found someone with the exact same symptoms and issues I was having!
So rather then trying anything else I replaced the dist cap and rotor, I barely turned the key and she fired right up!!!
Thank you everyone for all of your input!!!!
Last edited by swartlkk; 09-14-2011 at 12:48 PM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Old 09-14-2011, 01:05 PM
Glad you got it fixed!
Old 09-14-2011, 11:46 PM
moon is on a distinguished road
try checking voltage at the coil while cranking engine to see if its dropping out just had a honda that was doing same thing was a bad switch found it accidentally was letting off switch an it started up then died.
bryanmine
05-19-2011 11:27 AM
stschuyler25
11-21-2010 09:34 AM
chiajake
04-02-2008 11:21 AM
ndekens
11-14-2007 09:47 PM
Quick Reply: Blazer will not start, I'm at a loss!!!
