-   -   blazer wont start (https://blazerforum.com/forum/engine-transmission-35/blazer-wont-start-15669/)
Asimm 12-25-2007 01:59 PM
blazer wont start
Ok my blazer has been sitting out side and wont start it started earlier today but when i went to go restart it wouldnt... the battery has not been used in over 3 inths and has been outside.. and i didnt let it run for a long time during th first start up... is it becouse the battery is completly dead... but all the accesories work it wont even crank when i turn it to the start...
swartlkk 12-25-2007 02:39 PM
RE: blazer wont start
Have you tried to jump start it? I would remove the battery connections and make sure that they are clean.
Asimm 12-25-2007 04:13 PM
we tried to jump start it took a while the first time to start but wouldnt start the second time so we tried to jump start it again it then proceded to not make a noise when you turned it to start but all the electronics worked. we thought we blew a fuse but we checked all of them and there was problem there.. but i just went out to see if it would make a noise when you try to start it and it made a little faint noise like the electricity was tring to start it but there wasnt enough power... hopefully i can just get a new battery and that will be it.
Hanr3 12-27-2007 03:56 PM
take the battery to your parts store and have them test it.
Check your battery cable to the starter and the starter connections too.
