-   -   blown head gasket? (https://blazerforum.com/forum/engine-transmission-35/blown-head-gasket-8493/)
bigt Feb 2, 2007 10:18 AM
blown head gasket?
When you blow a head gasket what is the most probable cause for it happening? Are the heads warped? Thanks
Chevy Lover Feb 2, 2007 03:23 PM
RE: blown head gasket?
Probable cause for head gasket failure : overheating due to coolant leaks, stuck thermostat, plugged cooling system. Lack of service, changing coolant and flushing the cooling system
When you have a blown head gasket, it's always a good idea to get the head checked for warpage.
bigt Feb 3, 2007 09:10 AM
Thanks for the advice!
