Bucking on Highway
2000 Blazer Zr2 just over 170,000 kms
Just started doing it this winter. Any speed between 80km and 100km I can feel the vehicle stutter / buck.
Only seems to happen while holding the speed. Don't feel anything if I go right through to 110km
No drop in RPM or speed.
If I go above or below there is no issue.
New fluid and filter changed on the weekend with no change
Any thoughts?
Any thoughts?
Any thoughts?
Any thoughts?
Reminds me of the time my TCC lockup solenoid started to fail on my Camaro...Anywhere between 60 - 70MPH , the TCC would lock , unlock , lock , unlock..If I hit 80MPH , the thing seemed fine....If i put the thing in 3rd instead of Drive\OD it wouldn't happen..
Any thoughts?
Any thoughts?
Could be other things, but something to consider. I was really surprised when trans went out (on a 275 mile RT drive), and then problem was gone when trans was fixed again.
Any update on this? I had a weird bucking/jerking in my 03 Blazer on the highway today. Happened three times, but then didn't do it again when I drove it on the highway again later in the day. No codes, shifts normally, engine runs good.
Took it into transmission place shortly after the last post and they couldnt find any issue and thought every thing ran great.
I think it has something to do with the over drive. As long as it stayed above 2k rpm it ran smooth. From what I remember anyways, as it has been running with out issue since spring.
We just got snow today and I kind of wondered if the issue would start back up.
