-   -   Bypassed Rubber Hose (https://blazerforum.com/forum/engine-transmission-35/bypassed-rubber-hose-96776/)
Transman304 04-26-2018 04:55 AM
Originally Posted by Rusty Nuts (Post 689436)
When you disconnect the hoses from the vacuum switch on the transfer case check the inside of those hoses for fluid as well. They're supposed to be dry.
Great tip! Not sure if his model will be equipped with that switch. That switch was known as the vampire. Suck the fluid right out of the transfer case. :D
error_401 04-28-2018 12:04 PM
I'm a bit late with checking the OEM Manual. Correct about the hose.
This should be the vent to atmosphere of the "TRANSFER-CASE" vacuum switch.
Normally it is just the hose which has a clamp and a sponge cover. It is used as a vent.
There should definitively be no fluid coming out of there.
To make sure we do not mix up things here.
From front to back we have: ENGINE - TRANSMISSION - TRANSFER CASE
The transfer case is bolted together with the transmission and as previously stated a leaking seal could dump TRANSMISSION FLUID into the TRANSFER CASE.
The fluid for the TRANSFER CASE is also automatic transmission fluid.
Service manual says DEXRON IIE.
christine_208 04-28-2018 01:30 PM
Is not the fluid a special kind if you have a "4-button" transfer case?
error_401 04-30-2018 02:57 AM
More recent blazes could be. The 94 is the last 1st gen. Electrically actuated Blazers have only one switch with two positions.
Manual says DEX IIE for the transfer case and DEX IIE or IIIE for the transmission on these Blazers.
