Cannot stop coil wire from arcing
!995 GMC Jimmy SLE 4.3 L
Trying to stop random misfiring. Replaced spark plugs, wires, distributor cap, rotor, and ignition coil. Did not help misfire problem at all. Waited til after dark to look for arcing spark plug wires and the only one arcing is the coil wire. Tried rerouting it but it arcs against anything it gets close to, even the heater hoses. Tried another new wire with same results. I also noticed arcing on the body of the ignition coil. Any suggestions on what I might try next? Thanks. |
are you sure all the wires snapped into place properly?
(Post 669013)
So that's it? The only thing that could cause this problem is a loose wire?
The tower on the ignition coil is cracked, I had the same issue on my Zr2. A new one will run 30-40 bucks. You will need to drill out the rivits to separate it from the ignition module and the new one should come with bolts.
Originally Posted by cmockensturm
(Post 669703)
The tower on the ignition coil is cracked, I had the same issue on my Zr2. A new one will run 30-40 bucks. You will need to drill out the rivits if the coil is original to separate it from the ignition module. The new one should come with bolts.
Sorry I missed that in the first post. I have run into an issue using non Acdelco parts on the ignition as well.
