| Chiller449 |
03-01-2017 08:16 PM |
Cant find Engine temp Sender 1 pin 1991 s10 blazer
Hello,
So my temp gauge is not working in my truck. So I found the sensor on the passenger side of the engine block and removed the connector. Its a single wire. I touched it to ground to test the gauge and the gauge is working. This tells me the sensor is bad. So I go to Advance auto parts to order a new one. They either cant order it or cant find one that has a single pin on it. All they can find is the double pin. I already replaced that one. It goes next to the thermostat housing. I called some other shops and they cant find a single pin sensor either. Does anyone know where I can buy one or have a part number that I can use to find the one I need??
