Can't solve oil Leak
Old Apr 4, 2013 | 08:37 PM
Ash's Blazer's Avatar
Ash's Blazer is on a distinguished road
Default Can't solve oil Leak
Just bought a 98 blazer with a pretty big oil leak. Seems to be coming from the oil pan, but cannot tell it's so tight in there.
Questions:
1) Is it possible to change the oil pan gasket without pulling tranny or otherwise? Please say yes.
2) The majority of the leak seems to be above the starter on the passenger side of the engine. What's above that? I looked at the valve cover, and while it's moist it's not leaking oil onto the exhaust manifold???
Old Apr 4, 2013 | 08:41 PM
chris015's Avatar
if its not the pan,its going to be the oil sending unit or valve cover gasket. nothing else on passenger side,MAYBE distributor gasket. but doubt it.
Old Apr 4, 2013 | 08:48 PM
richphotos's Avatar
and to answer your question on changing the pan gasket, that depends, 2wd or 4wd
Old Apr 5, 2013 | 12:07 AM
4wd.
It's so tight in there, I can't even get a hand wrench in there to tighten oil pan bolts.
Old Apr 7, 2013 | 05:07 PM
abig84's Avatar
just had a similar issue on my fullsize 90. ended up being my pcv system was clogged solid and not working, my intake gasket blew in the pass side back corner and was spewing oil out as that was the only place it could vent. left like a 3 inch puddle after 10 minutes of running.
Xavier
14
Feb 21, 2012 03:47 PM
247monster
Dec 30, 2011 06:09 PM
Digbee1401
14
Sep 8, 2011 10:43 AM
Blessed23
Jul 11, 2010 11:40 AM
deadpool
Apr 24, 2007 04:08 AM
