-   -   Car Jerks/Bucks when accelerating quickly.. (https://blazerforum.com/forum/engine-transmission-35/car-jerks-bucks-when-accelerating-quickly-63181/)
roflwaffle08 Sep 16, 2011 08:28 AM
Hello everyone, first time poster, long time reader.. I love your guys stuff here..
I own a 98 Blazer LT, 4wd
Anyways, I've got a strange issue and I'm not sure what it is.
Whenever I accelerate from a stop only, around 2500-3000rpms, my Blazer starts to buck or jerk when it accelerates. I've been thinking this is a transmission issue, but I'm not sure anymore. It doesn't seem like its slipping, this bucking doesn't happen around a shift point.
I'm not sure I can say its a fuel/air issue either though, because its entirely fine at high speed/acceleration past 25mph. I've gone through a list of thoughts, MAF, Throttle Position Sensor, just not sure where I should look first.
Thanks!
roflwaffle08 Sep 16, 2011 11:43 AM
I recorded a video to give an idea of what I'm talking about. It's not doing it as bad as it was, but at about 4 seconds the RPMs drop back down real quick, and the car jerks.. It happens again later in the video as well..
Car jerks when accelerating quickly - YouTube
drewsblazer Sep 16, 2011 02:57 PM
if this happens to get worse as the car heats up, check your wires and ignition coil at night to check for arcing. mine had a similar problem as yours start there.
roflwaffle08 Sep 16, 2011 02:58 PM
New plugs/wires a few months ago, haven't had a look at the coil yet though, and I know the car has had some electrical problems in the past.. will check tonight, thanks!
1sikBLAZR Sep 16, 2011 09:34 PM
mine does something similar i think my trans fluid levels arent right
roflwaffle08 Sep 19, 2011 10:03 AM
I'm thinking now more than ever that its just simply the trans going out. I think I'm going to get with a friend who has a tool to be able to scan it to make sure before I shell out the $. Thankfully he'll rebuild it for a fair price, can't complain, it's worth it.. thanks for the help again
mrkevinmjr Sep 19, 2011 06:43 PM
check mounts... same happened here and mech is changin mounts... i looked under hood while doing a power brake and watched the engine jump around
