car slows down quick
hey again my 1999 4 door blazer feels like it slows down very quickand whenever I speed up I feel like something is pushing it back i.e. don't get the power/speed expected!
I've recently done some tune up air filter, spark plugs, wire, disrbuted cap & rotor all were changed,but it's still doing the same thing!
Any thoughts?
Any thoughts?
How does it idle? Have you checked the fuel pressure? How about rapping on the catalytic converter with a wooden dowel or rubber hammer to listen for a rattling noise? If there are no other symptoms, I would suspect a fuel supply problem or a plugged catalytic converter.
Yeah I would check the e-brake, then make sure you arent in 4hi or something like that. Some other thoughts are that you need to change the differential fluids and/or the transmission fluid. Otherwise my guesses would be either a fuel delivery problem, which shouldn't make it slow down fast, or a dragging brake pad which could cause it to slow down fast and have a bunch of resistance to overcome to get going. Hope this helps, keep us informed.
I'vedoubt if it was thee-brakes. BecauseIpull it every now & then. Plus, I've never really used them, maybe once since I bought it! I mean I could be doing 65 mph on straight roadthen I take my foot of the gas pedal the speed reduces very fast it feels that I'm pushing the brake. Another thing when ever I put the gear ondrive on straight road the car wouldn't move and if it does you'd barely feel it!
with your last post it sounds like you could have some potential transmission problems. It could be your torque convertor, best bet is to have someone check out your drivetrain. I would also suggest checking the transfer case.
