cat prob
cat prob
ok my cat plugged on my 95 blazer thats not the prob tho i got the nuts loose and all i just cant get it to twist off from the front pipe its the stock cat and is rusted any tips maybe heat it up or somthing
RE: cat prob
If it rusted on you may need to cut it off.
RE: cat prob
was hopein i wouldnt have to cut it cause its one of those cats that has the pipe on it that connects to the muffler i direct fit one i belive the call it not one were u have to weld it on
RE: cat prob
Mine bolted onto the y-pipe on one side and the muffler on the other. When I replaced just my muffler I used a torch and heated them off. then they just snapped off and I was able to use new nuts/bolts. When I had to replace my clogged cat I tried the same thing and couldn't get them off so I just cut it off and clamped a straights pipe in place.
RE: cat prob
PB Blaster
LSpoweredStepside
09-30-2013 09:22 PM
Melrock83
09-03-2012 08:37 PM
djbass_mekanik
Headers, Intake, & Exhaust
04-22-2006 06:15 AM
